I want to filter to a list of sheets with sheet numbers specified in a list. This is where my understanding of lists ends. How do I use levels and lacing to achieve a list of my 19 sheets (from my code block with all the Sheet Numbers) in the “In” output of the Filter by Boolean Mask node? So far I am only getting results in the “Out” output.
A few different ways to do it. I’d probably just set the == to cross product with list levels off and that should do the trick. Or you can leave lacing on default and run X@L1, Y@default with a flatten before the input. Then you can use an ‘AnyTrue’ node, or ‘List.Contains’ with ‘true’ before your ‘BoolMask’.
I see the difference in list structures at your end results, so that is helpful for my planning.
However, I am still not getting my desired results, see below:
Your method 1 (green groups):
Your method 2 (salmon groups):
EDIT: I simplified the script and got the result I expected. Still, I don’t see how to apply this basic version to my original situation. Would you please bridge this gap?
Your mask has been sorted but your list hasn’t, so you’re using the right true/false value but on the wrong list. Either feed the sorted list into the BoolMask, or skip the sort node and sort after filtering.
That did it. I was convinced I had done the lacing or levels incorrectly so I didn’t catch my unfinished sorting. Thank you.
My example utilized Auto lacing in all cases - you set the nodes to longest which will change the way the nodes process the data. ![]()
I looked for Auto lacing but I didn’t see it in the lacing options. I tried unchecking Longest but that just went to Shortest. I’m using Dynamo in Revit 2019, could that be why I don’t see Auto?
Which Dynamo version? Pretty sure it was a thing in Dynamo 2.X in Revit 2019, but I might have it the wrong way around.
Likely you’re in the version of Dynamo which comes pre-installed with Revit 2019. I blieve it’s 1.3.2 or 1.3.4. I highly recommend upgrading to 2.0.4 as that will enable the graphs you build for 2019 can be more easily upgraded to work in Revit 2020 and beyond, where there is a file format change with the 2.3 or later format.
You’re right, I haven’t installed any updates. I’ll do so, thanks for the suggestion!
