Im having some trouble filtering my list for some reason…
I have a list of strings coming from an excel file that match pattern types in Revit, I have 136 items in the list that i want to match with a fill pattern, goal is to have a list of 136 fill patterns, the String. Contains node seems to hav
Hi
Change inputs! For String.Contains SearchFor will be your list from excel.
then you need to find if one of the items in the list is true. Use booleans.AnyTrue
Also set lacing of filter by bool mask to auto not cross product
Neither solutions actually get what I need, if 100 patterns come from the excel file, each one needs to be linked with a fill pattern in the model, so the output needs to be 100 fill patterns in the order in which they were entered, maybe this table will help explain…
Haha, sorry pal, I was cutting corners here.
In the filter input the list of patterns with the list of booleans and it will return a list of patterns. As long as you have the boolean list you can filter anything you like as result.
