Hello everybody
I was studying dynamo and am having problems with stackedwall, I can not assign parameters for the wall in stakedwall
thanks
Mark = Text Parameter, and you’re using numbers. Try String from Object node.
Hi Hyun,
It it will be good if you can put rvt file here. So that we can have closure look at your issue and provide you solution.
Project1 Stakedwall Thanks KULKUL ^^
<b>Thanks KULKUL and Happy New Year ^^</b>
