HELP! All Revisions Per Sheet to Excel
Interesting topic. Just to understand a bit more…
are the current revisions in the views or on the sheets?
depending on which, it will change the extraction logic drastically.
  • if it’s a view based revision, you’ll need to extract from the views and get the sheet number references
  • if it’s a sheet based revision, the extraction should begin from the sheets. you may not be able to extract the viewport reference easily. need to consider building a bounding box for the viewport size and target the elements within.
the logic pathway could go many ways but it’s good to understand how the revisions are being modelled first for a start I feel.
For a start, have you tried OOTB plugins like pyrevit where it gives you a report based on the following.
or DiRoots trial SheetLink to get you by.
Sample workflow based on the View Revision Clouds.
output below;
thanks for the suggestions. I do have pyRevit but I was hoping for a more detailed report like the one you generated. I see a node called “lists.clean” is that a custom node? The only one I see when I type that in is the “list.clean” command, and requires a “preserveIndices” input, the icon also looks different.
a solution with Python
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
import pandas as pd
from openpyxl.worksheet.table import Table, TableStyleInfo
from openpyxl.utils import get_column_letter
def autosize_columns(df, ws):
    A function that sets the width of each column in a given worksheet (ws) based on the maximum length of data in each column in the Pandas DataFrame (df).
    Args:
    - df: Pandas DataFrame containing the data to be written to the worksheet.
    - ws: Worksheet object representing the worksheet where the data will be written.
    Returns: None
    margin = 7
    lstvalues = df.values.tolist()
    lstColvalues = df.columns.values.tolist()
    column_widths = []
    for row in [lstColvalues] + lstvalues:
        for i, cell in enumerate(row):
            current_lenCell = len(cell) if cell is not None else 1
            if len(column_widths) > i:
                if current_lenCell > column_widths[i]:
                    column_widths[i] = current_lenCell
                column_widths += [current_lenCell]
    for i, column_width in enumerate(column_widths, 1):  # ,1 to start at 1
        ws.column_dimensions[get_column_letter(i)].width = column_width + margin
out_xls = IN[0]
lst_value = []
all_sheets = FilteredElementCollector(doc).OfClass(DB.ViewSheet).WhereElementIsNotElementType()
all_revision_clouds = FilteredElementCollector(doc).OfClass(DB.RevisionCloud).WhereElementIsNotElementType()
for sheet in all_sheets:
    all_views_in_sheet = [doc.GetElement(xId) for xId in sheet.GetAllPlacedViews()]
    # add primaries views
    all_viewIds_in_sheet = [v.GetPrimaryViewId() for v in all_views_in_sheet] + [v.Id for v in all_views_in_sheet]
    all_additional_revisionIds = sheet.GetAdditionalRevisionIds()
    all_revisionIds = sheet.GetAllRevisionIds()
    all_revisions = [doc.GetElement(xId) for xId in sheet.GetAllRevisionIds()]
    all_revisions.sort(key = lambda x : x.SequenceNumber )
    for rev in all_revisions:
        onwerView = ""
        rev_clouds = [cld for cld in all_revision_clouds if cld.RevisionId == rev.Id and cld.OwnerViewId in all_viewIds_in_sheet]
        if rev_clouds:
            onwerView = doc.GetElement(rev_clouds[0].OwnerViewId).Name
        lst_value.append([sheet.SheetNumber, sheet.Name, rev.Name, rev.RevisionDate, onwerView, rev.Description ])
with pd.ExcelWriter(out_xls, mode="w", engine="openpyxl") as xlsx:
    df = pd.DataFrame(lst_value, columns = ["SheetNumber", "SheetName", "RevisionName", "RevisionDate", "OwnerViewCloud", "RevisionDescription"])
    df.to_excel(xlsx, sheet_name="Revision", index=False)
    # get worksheet
    ws = xlsx.sheets["Revision"]
    table = Table(displayName="Table_Revision", ref="A1:" + get_column_letter(ws.max_column) + str(ws.max_row))
    # add a default style with striped rows and banded columns
    style = TableStyleInfo(name="TableStyleMedium9", showFirstColumn=False, showLastColumn=False, showRowStripes=True, showColumnStripes=False)
    table.tableStyleInfo = style
    ws.add_table(table)
OUT = lst_value
for info there is a new method since Revit 2024
I believe there are two types of list clean. One that preserves the indices for you and the other cleans the null values disregarding the index arrangements.
For these Views, I believe the null values belongs to the view templates hence why it appears as such.
No need for concerns though. They perform the same way so you could set the boolean to false as replacement.
Secondly, my approach to dynamo has always been to utilize the Core nodes first.
We shouldn’t be too reliant on the custom nodes in the beginning of Dynamo programming.
This allows us to understand the base capabilities of Dynamo.
Hope that helps with clarity.
