Grouping List items to one Cell in Excel
Hi guys,
Need help. I have created a graph to get info from Revit sheets and put it in Excel. But need to combine it into one cell.
ie:image
This shows my Drawing Number. Now I need to put this on a Specific Excel Sheet
Hope this is clear
@johan64YES I’m unable to see what your graph is because the node text isn’t visible (when taking a screen capture you need to zoom in until the text is legible; the capture will include your whole graph even if you are zoomed in and can’t see all of it) - looking at your first and third images, it seems you want to join your list of parameter values into a single string? If so using String.Join should work (disregard the group that says “list”, it is just generating a list that mimics yours to demonstrate):
Hope this helps! Apologies if I am incorrect on what you are looking for :slight_smile:
Thank you that makes sense.
Amy,
This is a stupid question so I apologise but hope this makes you smile at least. But I have the List item in sequence
ie:[0] List
[0]1
[1]A1
[2]8888
[3]ASL
[4]xx
[5]xx
[6]GN
[7]S
[8]0001 This is the standard PAS naming convention as you know. How do I take this data and transpose it to follow this
ie:8888-ASL-XX-XX-GN-S-0001 General notes. But this needs to be in one cell of excel. I can then create a field to host Page size and Revision.
In my head this makes sense hope it does for you
Thank you for your help
I have manged to use your graph (Thank you) and got this
One step closer but now i need them going down and not across
Amy,
Got it resolved thanks to you.
Thank you
Johan
