Hello everyone, I have this issue and need your advice. The grids in my project are out of the crop view (as you can see in the screenshot), I don’t know if there is a way to set the grids align with the crop view for multiple views at once? I would be very appreciated with your help. Thank you.
Yes this is possible. What is also possible is giving the search button a try first
I use python code from Forum… but it always make grid head to top and right.
How can I fix this code to make grid head top and “LEFT”?
[캡처]
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.Ad…
Is it possible to get the position of the grid relative to the crop region? The goal is to reposition the view on the sheet, positioning the grid crossing at a specific location on the sheet.
grid extents need to placed at crop region…
[image]
Version:0.9 StartHTML:00000097 EndHTML:00005232 StartFragment:00000199 EndFragment:00005194
# ProtoGeometry (Dynamo)
# API
clr.AddReference("RevitAPI")
# RevtiServices
from RevitServices.Transact…
Hello Dynamo Friends
Thanks to @c.poupin , @Nick_Boyts and @Mark.Ackerley i have a python code that sets the grid extents and i have a python code that sets the grid bubbles . Everything works great, but combining it in one dynamo graph does not work. After days of investigating I´m out of ideas.
First of all, the python code that sets the bubbles activates the left bubbles and if the grid is vertical it activates the upper bubbles. This works no matter in which direction the gri…
Look to be the same challenge with some solutions and scripts for them too.
Actually, I did search it from the beginning and found out a python script to do it. But it just applies for the active view and I don’t know python so I can’t edit it to apply for multiple views, that’s why mention it in my post. Anyways, thanks a lot for your help, I will take a look at these posts.
