Grid to crop line using python
I use python code from Forum… but it always make grid head to top and right.
How can I fix this code to make grid head top and “LEFT”?
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
def createDatumLine(boundLines, grid):
	gridLine = None
	curveG = grid.Curve.ToProtoType()
	vectGrid = curveG.Direction
	ptmid = curveG.PointAtParameter(0.5)
	lstPtToLine = []
	for lineBound in boundLines:
		lineBoundDs = lineBound.ToProtoType()
		ptmid = DSGeo.Point.ByCoordinates(ptmid.X, ptmid.Y, lineBoundDs.StartPoint.Z)
		interResultA = ptmid.Project(lineBoundDs, vectGrid)
		interResultB = ptmid.Project(lineBoundDs, vectGrid.Reverse())
		if len(interResultA) > 0:
			lstPtToLine.append(interResultA[0].ToXyz())
		if len(interResultB) > 0:
			lstPtToLine.append(interResultB[0].ToXyz())
	if len(lstPtToLine) == 2:
		gridLine = Autodesk.Revit.DB.Line.CreateBound(lstPtToLine[0], lstPtToLine[1])
	return gridLine
def getBoundLines(bbx, Zvalue = 0):
	lstPt = []
	lstLine = []
	lstPt.append(XYZ(bbx.Min.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Max.Y, Zvalue))
	lstPt.append(XYZ(bbx.Min.X, bbx.Max.Y, Zvalue))
	for idx, pt in enumerate(lstPt):
		if idx == 0:
			lstLine.append(Line.CreateBound(lstPt[- 1], pt))
			lstLine.append(Line.CreateBound(lstPt[idx - 1], pt))
	return lstLine
activView = doc.ActiveView
cropBox = activView.CropBox
fecGrids = FilteredElementCollector(doc, activView.Id).OfClass(DatumPlane).ToElements()
cutOffset = fecGrids[0].GetCurvesInView(DatumExtentType.ViewSpecific, activView)[0].GetEndPoint(0).Z
fecGrids = [x for x in fecGrids if isinstance(x, DB.Grid)]
outLst = []
boundLines = getBoundLines(cropBox, cutOffset)
for grid in fecGrids:
	newGLine = createDatumLine(boundLines, grid)
	if newGLine and True:
		grid.SetCurveInView(DatumExtentType.ViewSpecific, activView, newGLine)
		outLst.append(newGLine)
OUT = outLst
Ah, I have been using the same code recently for a different purpose.
You need to incorporate a set of additional conditions in the boundline definition.
  1. Assess if the boundline is vertically oriented to the view, as to filter out only the horizontal boundlines.
  2. Checking the start and end point of the horizontal boundlines, and reversing it’s direction if the X value of start point is greater than the X value of the end point.
The above depends on the view being orthogonal with the X and Y axis where they are expected to be, which might not be entirely accurate if the view is using a rotated scope box.
What view orientation do you have?
Do you have python programming experience?
This is not the easiest place to start working with Python/Revit via Dynamo, but if you give it a go and post your attempts, we are here to guide you towards a solution.
Thank you reply.
First of all, I need check word.
  • boundline → crop line
  • horizontal boundlines → crop view parallel with plan view
Is it right?
  • It is plan view and never rotated
  • I learned about python programming several month, Can’t make code, but read code in elementary level.
	return gridLine
I thought in this line, (lstPtToLine[0], lstPtToLine[1]) change these value to (lstPtToLine[1], lstPtToLine[0]), but It’s wrong. because right grid head turned into left head grid and top head grid turned into down head grid.
Fianlly I thought, if I get hor-grid startpoint-endpoint reversely, this problem will be fixed.
but It’s difficult to change code
You are thinking along the correct lines.
Have a look at the logic here, then give it a go :wink:
	gridLine = None
	lstPtToLine = []
		# Enforce Line Orientation
		if lstPtToLine[0].Y > lstPtToLine[1].Y:
			# The grid is vertial and starts from the top
		elif lstPtToLine[0].X < lstPtToLine[1].X and lstPtToLine[0].Y == lstPtToLine[1].Y:
			# The grid is horizontal and starts from the left
			# The grid orientation is incorrect, swap the direction
			gridLine = Autodesk.Revit.DB.Line.CreateBound(lstPtToLine[1], lstPtToLine[0])
	return gridLine
Good morning! It’s 8 o’clock here
lstPtToLine[0].Y means y coordinates of point !
I understand what you want to do in IF function, but also can’t understand this
	return gridLine
I already tried swiching lstPtToLine[0] <-> lstPtToLine[1] in previous code but it failed.
There is no differences defining IstPtToLine but swiching in “else” function is successful
What’s difference in two? (just swich “IstPtToLine[0], lstPtToLine[1]” in previous code, and if …
oh, I understand.
That “IF” code means
Not make grid in same time like previous one, but make grid step by step.
vertical? ok~ horizontal? no → swap . oh I see
	gridLine = None
	lstPtToLine = []
	return gridLine
Result is good, grid head appear right and bottom. but I change all point( 0->1 , 1->0) in your code
It’s solved. very very thank you for your help!
Glad to hear it works for you. :+1:
Please mark the solution for anyone else who visits this topic in future.
	return gridLine
ah… one more thing plz?
I think It should be work on elevation, because of “else” phrase
but It isn’t.
why this problem happened?
This is likely because the Grid ‘Curves’ are now vertical specific to the view and so need to be extracted slightly differently. I’ll have a look when I get a chance.
thanks !!
