Grid extents alignment based on crop region
grid extents need to placed at crop region…
Version:0.9 StartHTML:00000097 EndHTML:00005232 StartFragment:00000199 EndFragment:00005194
# ProtoGeometry (Dynamo)
# API
clr.AddReference("RevitAPI")
# RevtiServices
# RevitNodes, ToDSType method, Geometry conversion
# defs
def Convert(num):
return UnitUtils.ConvertToInternalUnits(num, DisplayUnitType.DUT_MILLIMETERS)
# start
view = UnwrapElement(IN[0])
av = doc.ActiveView
#Top Grid
deltatop = IN[1]
#vatopx = Convert(deltatop[0].X)
#vatopy = Convert(deltatop[0].Y)
#vatopz = Convert(deltatop[0].Z)
grids = [UnwrapElement(item) for item in IN[2]]
#Bottom Grid
deltabottom = IN[3]
#vabottomx = Convert(deltabottom[0].X)
#vabottomy = Convert(deltabottom[0].Y)
#vabottomz = Convert(deltabottom[0].Z)
for g in range(len(grids)):
    newStart = XYZ(deltatop[g].X, deltatop[g].Y, deltatop[g].Z)
    newEnd = XYZ(deltabottom[g].X, deltabottom[g].Y, deltabottom[g].Z)
    newCurve = Line.CreateBound(newStart, newEnd)
    grids[g].SetCurveInView(DatumExtentType.ViewSpecific, view , newCurve)
# end
OUT = grids
File “”, line 54, in
Exception: The curve is unbound or not coincident with the original one of the datum plane.
Parameter name: curve
please help on this error.
Why not just Element.SetParameterByName?
no its not possible. I need to move the grid extent beyond the crop boundry
Hello @dhilipseshan
you need to get the “cut elevation” CutPlane of the view to set elevation of bounds curve (CropBox)
an example with the active view
clr.AddReference('RevitAPI')
def createDatumLine(boundLines, grid):
	gridLine = None
	curveG = grid.Curve
	vectGrid = curveG.Direction
	ptmid = curveG.Evaluate(0.5, True)
	lstPtToLine = []
	for lineBound in boundLines:
		interResult = lineBound.Project(ptmid)
		vectInterResult = Autodesk.Revit.DB.Line.CreateBound( ptmid , interResult.XYZPoint).Direction
		if vectInterResult.IsAlmostEqualTo(vectGrid, 0.1) or vectInterResult.IsAlmostEqualTo(vectGrid.Negate(), 0.1):
			lstPtToLine.append(interResult.XYZPoint)
	if len(lstPtToLine) == 2:
		gridLine = Autodesk.Revit.DB.Line.CreateBound(lstPtToLine[0], lstPtToLine[1])
	return gridLine
def getBoundLines(bbx, Zvalue ):
	lstPt = []
	lstLine = []
	lstPt.append(XYZ(bbx.Min.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Min.Y, Zvalue))
	lstPt.append(XYZ(bbx.Max.X, bbx.Max.Y, Zvalue))
	lstPt.append(XYZ(bbx.Min.X, bbx.Max.Y, Zvalue))
	for idx, pt in enumerate(lstPt):
		if idx == 0:
			lstLine.append(Line.CreateBound(lstPt[- 1], pt))
			lstLine.append(Line.CreateBound(lstPt[idx - 1], pt))
	return lstLine
activView = doc.ActiveView
cropBox = activView.CropBox
viewRange = activView.GetViewRange()
cutOffset = viewRange.GetOffset(PlanViewPlane.CutPlane)
fecGrids = FilteredElementCollector(doc, activView.Id).OfClass(DatumPlane).ToElements()
outLst = []
boundLines = getBoundLines(cropBox, cutOffset)
for grid in fecGrids:
	newGLine = createDatumLine(boundLines, grid)
	if newGLine:
		grid.SetCurveInView(DatumExtentType.ViewSpecific, activView, newGLine)
		outLst.append(newGLine)
OUT = outLst
@c.poupin. Thank you so much.
your work is amazing.
I am looking into this many times to understand.
but i think i missed to specify diagonal grids as shown in image.
is that possible for diagonal grids also?
Hello @dhilipseshan
I had not considered this scenario :grinning:
try this version
  • Edit 03/02/2022
    fix bug
import Autodesk.DesignScript.Geometry as DSGeo
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
	gridLine = None
	curveG = grid.Curve.ToProtoType()
	ptmid = curveG.PointAtParameter(0.5)
	lstPtToLine = []
		lineBoundDs = lineBound.ToProtoType()
		ptmid = DSGeo.Point.ByCoordinates(ptmid.X, ptmid.Y, lineBoundDs.StartPoint.Z)
		interResultA = ptmid.Project(lineBoundDs, vectGrid)
		interResultB = ptmid.Project(lineBoundDs, vectGrid.Reverse())
		if len(interResultA) > 0:
			lstPtToLine.append(interResultA[0].ToXyz())
		if len(interResultB) > 0:
			lstPtToLine.append(interResultB[0].ToXyz())
	return gridLine
def getBoundLines(bbx, Zvalue = 0):
	lstPt = []
	lstLine = []
		if idx == 0:
	return lstLine
cutOffset = fecGrids[0].GetCurvesInView(DatumExtentType.ViewSpecific, activView)[0].GetEndPoint(0).Z
fecGrids = [x for x in fecGrids if isinstance(x, DB.Grid)]
outLst = []
	if newGLine and True:
OUT = outLst
another version here
@c.poupin.
Thank you so much.
This is working perfect even for diagonal grids also.
Its not work for Elevation plan, can you fix it, thank you so much!
Start new topic original post is already solved.
