Edit Grid lines 2d Extend in Multiple Views
How to set start point/ end point for all grids through Different Parallel Views with dynamo?
Because Propagate does not work for views with scope box or crop, so we need a way to move all of them or go through each views
Hi Jin,
What have you tried so far? Have you searched the forum for other similar posts? Can you share how you think you might go about solving your problem and post images of where you get stuck?
There are a good few posts on the topic already which might help guide your thinking:
Please try to search the forum for similar topics before posting new ones.
Also try searching your dynamo nodes to see what might be available for you to use, for example:
Feel free to come back and add to this topic if you are having issues with your script.
Thank you! I will go through these posts firstly.
