yes only select one edge (direction) and one surface at time, and run from Player for avoiding element binding… if you have different surfaces with different gridsizes hope it helps
but i want to select top faces of all the floors( beacuse of which i have to select edges in each floor) and grid size will be same in each floor.
is possible to extract the coordinates of all the points that are with in a distance 6 feet from the all the edges
Yes it is…Join your perimeter curves to polycurve and offset 6 feet then explode polycurve and intersect the curves and then you have the coordinate point
Datashapes grid(6).dyn
what changes i should make to achieve 2 things?
- that it select all the edges of the selected face.
- and separated list of coordinates for the points that are with in 6 feet distance from each edge. even from the opening at the center of level 2.
thankyou so much but i want excel sheet of coordinates all the intersecting point that are in 6 feet distance from all edges.
sharing a rough sketch for reference
I am getting coordinates at all these intersecting points(red points) in an excel sheet using this dynamo file
Datashapes grid(6).dyn (174.1 KB)
i am asking how can I made certain changes in this script that it will give coordinates of only those intersecting points( that is the blue bold points in handmade sketch) that are with in 6 feet from all edges even the opening in the center.
looking for your response. thankyou for such concern means alot
Cool…for export point to excel, i had shown in post #20…for the other things i will take a look later…you know time but anyway i think i already had shown all possible combinations
yes. that had helped a lot.
yes sure please look at it later i am hoping that you understand my query.
hello. hope you are doing great. last time you helped me a lot and made things easy and understandable for me.
I am working on the same script till now I wanted to know if it possible or not.
I have two scripts one that you helped me with for getting the coordinates at all the intersecting points (yellow). i made another script for making lines at 6’ from edges.
i want to get the coordinates at the red points on the line 6’ from edges. i am able to get all the coordinates on the intersecting point (yellow points) but I am not able to get these red coordintes.
sharing images for reference.
final map.dyn (251.4 KB)
Cheers Fil…all good here hope the same for you…, yes it should be possible, I will take a look later…you know time ;)…could you share the rvt as well…dont think i have it anymore…/Søren
the actual model
have you checked?
Dont have the time right now…watch football Denmark vs Belgium ;
