Graphs Not Saving:
Hi All,
Newbie here. When I create a working script, save it; then re-open – I am missing nodes and the script no longer works. I have created these from scratch and have done so a couple times to make sure I wasn’t crazy. What could I possibly be doing wrong with a Save As? I just installed the latest daily.
This sounds weird… Can you link to a recording of the issue in action? Can you confirm it happens in 2.0 or is it just in the latest daily? Is there anything unusual about your setup (ie: a remote desktop environment)?
Thanks for your reply, @jacob.small.
It was weird (past tense)!
Nothing unusual about the setup, but it happened all morning.
Dynamo Core 2.0.1.5005
Dynamo Revit 2.0.1.2056
I probably restated my computer four times, with the last being the charm apparently.
I made three recordings and the problem never presented itself again.
Thanks for your time!
I had posted about these notifications recently regarding another issue I was having, but was told the latest daily should fix it (which it did) although I might have trouble with the color palette node. Perhaps they could be/have been related to this issue…
Perhaps, but not likely. That library shouldn’t impact saving in any way. Glad things worked out in any case. :slight_smile:
(Small side note: what you create in Dynamo is generally called a “graph” instead of “script”, everyone will understand what you mean but some people will get their feelings hurt).
Will do, @PauLtus. I certainly don’t want to hurt anyone’s feelings.
Thanks! :slight_smile:
