I have tried working a whole lot with roomcalculation points, and have thereby found that they do not find rooms from linked files…
Therefore I have tried going about it, via Dynamo. So what I have done is get the rooms, from the linked file, where I get their bounding box coordinates. Afterwards I have collected the coordinates from the airterminals, that i want the roomnumbers written to. Tried to use the function “bounding box contains” to see, if the airterminal is inside the room, whereafter i want dynamo to write the roomnumber wherein the airterminal is. But I have no clue, if I am going about this the wrong way. Here is my graph:
Here is the place I think it all goes wrong, beacue it only finds one room
Here is a picture of my ceiling plan, which has the airterminals and the room I want it to belong to:
The node Elements in Room doesn’t work with curves (pipes, ducts, cabletrays…)
But in your original post you talaked about the airterminals.
So first does it work well with the airterminals ?
