Getting wrong Solid shape when selecting Geometry in Revit
Hi guys,
Im currently working on a script that, as a small part of it, takes geometry from Revit to Dynamo for export to .SAT.
Everything is fine, but when it comes to Solids from “Duct_Round_Bend” it gives me a complete Donut-shaped geometry… Quite neet if you are hungry, but I only need the correct shape like 90 degree bends or so …
Do you awesome Dynamo Pioneers have any idea why this happens? Are you able to point me in the correct direction or do you even have a hot fix?
Thanks / Cheers!
Are you using Standard Revit library families or custom ones?
Can you attach a basic stripped copy of RVT file? EG (eg. pipe, bend, pipe)
Did you try Element.Geometry already?
Yes I’ve already tried Element.Geometry with the same result.
I’m stripping a model to attach
@Ewan_Opie, here is the stripped .RVT model.(Revit 2018)
The families should be standard.
