i want to filter al my structural elements, floors, walls, slabs, beams,…
so how can i do that well
my code works partly
clr.AddReference('RevitAPI')
clr.AddReference('System')
collectorWalls = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls)
placedWalls = collectorWalls.WhereElementIsNotElementType().ToElements()
collectorColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns)
placedColumns = collectorColumns.WhereElementIsNotElementType().ToElements()
collectorFloors = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors)
placedFloors = collectorColumns.WhereElementIsNotElementType().ToElements()
staticFloors = []
for i in UnwrapElement(placedFloors):
if i.get_Parameter(BuiltInParameter.FLOOR_PARAM_IS_STRUCTURAL).AsBoolean() == True:
staticFloors.append(i)
pass
OUT = placedWalls,placedColumns, placedFloors, staticFloors
KR
Andreas
Parameters don’t have an AsBoolean() method. Use AsInteger() instead.
@Nick_Boyts
for any reason it still remains as an error
is there any other error? or a better way to handle it?
You still have an issue with at least one element not having that parameter, which is why it’s returning NoneType. It looks like you copied the line from placedColumns and didn’t change it for floors, so you’re using the collector for columns in line 33.
@Nick_Boyts ,
placedFloors = collectorFloors.WhereElementIsNotElementType().ToElements()
staticFloors = []
if i.get_Parameter(BuiltInParameter.FLOOR_PARAM_IS_STRUCTURAL).AsInteger() == 1:
pass
OUT = staticFloors
it is missing the step to collect the elements ?
or do i precheck my elements and based on that collect my load beariing elements?
staticFloors = []
p = i.get_Parameter(BuiltInParameter.FLOOR_PARAM_IS_STRUCTURAL).AsInteger()
if p == 1:
pass
OUT = staticFloors
Your initial code was using the wrong collector. It looks like you’ve since fixed it? Are you still getting the same NoneType error?
So first I’d just return my list of floors to make sure that’s giving me the elements I expect. I’m not aware of a scenario where a floor doesn’t have that parameter but it may exist. In that case you would have to check for the parameter before getting the value.
