Find all elements
Is it possible to retrieve all elements from file, and not be depending on type or category? I am looking for Document.AllElements from Archi-Lab, but can find the node
@331173
you can do the job via python
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FilteredElementCollector
# 0ļøāƒ£ Get the active document
# 2ļøāƒ£ Collect all elements in the document
all_elements = FilteredElementCollector(doc).WhereElementIsNotElementType().ToElements()
# 3ļøāƒ£ Output the result
OUT = all_elements
First, you need to understand what an ā€œelementā€ is in Revit terms and if that’s really what you want. In Revit, ā€œelementā€ just refers to anything using the Element base class - which is most objects you can interact with. This isn’t just walls, floors, and pieces of equipment. Elements includes things like rooms, views, links, parameters, worksets, and tons of other various object types.
I assume that you, like most people, are after the model elements specifically - the physical elements that make up the 3D model. There’s no single method for getting all those objects, but a FilteredElementCollector is usually the way to go. You could use a collector to get all the FamilyInstances of loadable families and then you’d need separate collectors for the instances of the system families.
