Good morning everyone.
I’m trying to get the STRUCTURAL PILLARS that allow the placement of REINFORCEMENTS…I’m trying to find a way to do it all by PYTHON…
Using Python code.
I only need to capture those “STRUCTURAL PILLARS” that allow me to place “STRUCTURAL REINFORCEMENTS.”
What would be the method or property that allows me to perform this action?
TEST FILTER_ESTRUCTURAL COLUMNS.rvt (2.7 MB)
TEST FILTER_STRUCTURAL COLUMNS.dyn (3.3 KB)
you can use this method
Online Documentation for Autodesk's Revit API: 2015, 2016, 2017, 2017.1, 2018
import sys
import System
clr.AddReference('RevitAPI')
filterValidHost = System.Predicate[System.Object](lambda x : RebarHostData.IsValidHost(x))
GeneralColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns).WhereElementIsNotElementType().ToElements().FindAll(filterValidHost)
OUT = GeneralColumns
Hello, in your code, for establishing the filter (filterValidHost), is this class you are using?
Cordially
christian.stan
Yes .Net List can be filtered with FindAll() and a Predicate
alternatively, the use of PLINQ extension remains easily possible with IronPython
import sys
import System
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
GeneralColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns)\
.WhereElementIsNotElementType()\
.Where(lambda x : RebarHostData.IsValidHost(x)).ToList()
thanks
the filter method you are using is faster in case of a lot of elements, that’s why you are using it?
rather than this
cont=[]
TotalColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns).WhereElementIsNotElementType().ToElements()
for i in TotalColumns:
if RebarHostData.IsValidHost(i)==True:
cont.append(i)
pass
OUT = cont,TotalColumns
I have a preference for Predicate and PLINQ extension, but it is not necessarily the fastest methods
there are some tests here
Hello
for information, it is not because a code is shorter that it will be more efficient
some examples to compare execution times
with SlowFilter (Revit API)
[image]
with List Comprehension
[image]
with Predicate
[image]
with LINQ
[image]
with filter
[image]
Thank you for your always reasoned answers.
Have a good evening
Cordially
christian.stan
