Getting Geometry of wall openings of walls at an angle
Hey Folks,
I am trying to get a geometry of openings in walls, which are in certain angle. I am using bounding box way to do that. Ultimately, i want two edges of openings, which i will use for dimensioning,
image Openinginwallatangle.dyn (4.6 KB)
Please help if there is any better way to do this.
Thanks in Advance!! :slight_smile:
Hey, see if this is helpful… surface orientation and reassociating geometry to the wall are the key things…
Cheers,
Mark
Thanks, I will try this, will let you know if i dont understand. :slight_smile:
Hey,
I have been facing another basic issue though, posted here,
Do you know why this is happening?
Thanks!
Hey,
If you look at the method in the link, the base geometry of the wall is returned, so I presume openings would be included… Then that geometry is reassociated to the wall for dimensioning…
Cheers,
Mark
