Geometry of Openings
Hello everybody,
Does anybody by chance know a node/package/way to get the geometry of openings created in Revit, other than extracting by hand the informations through the parameters ?
Basically, I have a set of surfaces on Dynamo that represent (in a way) Revit objects, and I want to cut openings in the surfaces after operating on them (so I cannot simply intersect the surfaces with the imported geometry on Dynamo).
2018-07-31%2014_50_31-Dynamo
Thanks,
Mustapha
Can you please share all of your graph?
It’s basically it. I just selected the elements… Anyway, here it is.
test_openings.dyn (10.4 KB)
You can use the boundingbox when when everything failed.
Hi @Alban_de_Chasteigner, and thanks for the input.
Aren’t Bounding Box supposed to be aligned with the reference axis ? I mean, say that a have a wall that isn’t aligned with either the x axis nor the y axis and that one opening is situated on that wall. By using the Element.BoundingBox and the BoundingBox.toCuboid nodes, wouldn’t I get a solid that isn’t aligned with the initial element neutral axis ?
Are you talking of orthogonality ?
You score a good point. It doesn’t work properly with a diagonal wall.
Bbox
Yeah, I was talking about that :confused:
Maybe I can workout a graph to rotate the opening, create the BoundingBox and the Cuboid, and then rotate back the Cuboid… I think I already saw something like that on the forum, I better go get a look again.
Thanks anyway ! :slight_smile:
Hey,
Maybe this helps?
http://dynamobim.org/forums/topic/wall-openings-intersection-of-wall-geometry-with-elevated-wall-location-line/
You can get the location curves from the Element.Location node…
Cheers,
Mark
Thanks, i’ll take a look at it. I’ll tell you about any results I get tomorrow.
I have a better proposal with Element.Geometry+ from Clockwork.
Openings%202
Wonderful ! Thanks :slight_smile:
Where can I find the Deconstruct.Solid node? I tried the one in the Lunchbox package but it does not work.
My workflow, using Clockwork:
Hi, can you send the picture again? because it can not be read. Thanks
Hit the Ctrl button and the scroll wheel should do the trick
