How do we get the width of the wall opening through dynamo
I have a question.
How do we get the width of the wall opening through dynamo?
The properties field only has Unconnected Height.
You can extract the geometry of the openings this way :
And then try to compute yourself the widht/length/thickness by manipulating the points.
or like this
I’d avoid the bounding box method as that will return some bad results in some cases. This is my preferred method.
