Getting coordinates from linked revit file
I can get pile coordinates from Revit model but when i link the another project then it wont take the linked file coordinates.still it takes existing coordinates. Anyone give a solution for this.
please check the below attached dynamo file fPile co ordinates based on mark-testing.dyn (23.7 KB)
or your reference.
Did you check to change between Coordinate Origin in Edit Type of Spot Coordinate ( Survey Point - Project Base Point ).
Yah I checked that…its same as what you share
So it might be need to transform geometry to target coordinate system before reading the coordinates on it.
I attached my working dynamo file…can u mark on that.
Try below .
ok I will check and get back to you
Thank you
Thank you its working but if i followed survey point I did not get the coordinates instead of survey point.I used project base point. so ,final i got the shared coordinates. That transform works very well…nice one
Thank you once again…:slightly_smiling_face:
