Hi, is it possible to get a window location as a curve so I can offset a point from its axis? I think a way would be to get the windows end points and create a curve or line? Maybe get the geometry or bounding box and average that into a line or something? Or is a window not inserted with an axis dynamo can pick up to offset the line from its location point.
The graph im showing is what ive used with walls to offset the point
Hi vanman, windows in the model are family instances that are placed by point, so as you have checked in the graph.
I think using the BoundingBox is the way to go to get your desired line.
