Get points from curve
I try to extract points from curve that I offset from existing curve (I used curve.offset). Is there any node or package to do that?.
Thank you
Geometry.Explode
Curve.StartPoint
If those aren’t what you’re after, post your graph so we know what you’re up to instead of having to guess at your specific situation.
Thank you for your reply. I got the solution. I want to experiment how to manipulate the data inside dynamo.
(post deleted by author)
