Hey folks!
I’m creating a dynamo script that gets equivalent length of pipe fittings, (to comply with POMI/ NRM2) methods of measurement.
Is there a way to get the total length of sweep profiles of all fittings (type: elbow) from the project file?
Hint: depending on the elbow type (welded / Upvc / threaded), number of sweeps is either one or three.
Luffy11
September 17, 2024, 9:32am
2
hi @abdelrahman111 , I found a post that has a workaround to achieve what you want. I hope it can help.
The Building Coder: MEP Cable Tray Bend and Tee Analysis (typepad.com)
I’ve seen Jeremy’s post on LinkedIn today, by running the python script, it seems to work well ( a little below the exact length measured along sweep profiles, which can be handled with a safety margin ) .
I’m gonna update the topic with new thoughts.
Many thanks!
