Hi, I try to use pthon to get the location point of a structure, but fail. I checked the api, it should contain this code?
Hello, I am using Civil3D, do I need that too?
Oh sorry didn’t notice that you are using Civil3D. Perhaps it works
Hi, yes I know this too, but now I want to learn myself using API.
My utlimate goal is to update structure location without moving the connected pipes.
Oki, now I see.
Yes, there is a lot of nodes for that already, both to get location and set location, but good to learn how to understand it from the API side. I’m not there yet
I tried the civil3d toolkit, it has a node to set location of structure, but so sad the connected pipes will also be updated. For presentation purpose I need to move and rotate the structure to new position. So I need to learn myself to do it on my own by civil3d api. There must a way to do it, just not familiar with civil3d api.
Hi, my question is already using location property from api
my language is not good
so
Do I have a code or a picture
note
Python code does not work with package nodes Mostly
Write your code info code from like
Maybe
This help you
