Good morning, I’m trying to select a single vertical profile from a list that contains the word “VERTICAL” in the name.
follow my failed attempts
thanks in advance
thanks in advance
Use String.Contains
instead of List.Contains
String.Contains
will check for strings whereas List.Contains
checks for comparable objects.
In addition to what Nick said, the List.FilterByBoolMask node will be helpful after you have the list of booleans from String.Contains. The list input would be the Profiles, and the mask input would be the booleans.
Also, you’ll want to use a Profile.Name node after Alignment.Profiles. That way you have a list of strings to check instead of a list of Profiles.
Use FilterByBoolMask
like @mzjensen suggested so you don’t manually have to pick the item from a list.
17 / 5.000
I didn’t find this node
Ah sorry, I don’t think it exists
Look for CivilObject.Name instead.
just to explain the context.
I create several corridors and their vertical profiles
I want to create all the corridors at once instead of creating them one by one.
so i’m doing it step by step
The way you have it works, I was just suggesting you use CivilObject.Name in the place of String From Object. That way you’re getting the profile name directly.
now that i understand lol
I’m very dumb
This thread might be helpful.
I had seen this post, however I tried to use but the excel node gives error, so I am doing these to replace the ones that are giving error
