I have a project containing a lot of piping and I want to be able to select and filter them by system name. My selection grabs all of the piping in the project, but when I attempt to filter out all of the cold water piping (System Name contains CW) the output only contains one item. Is there a certain way this should be done with system families that is different from how it is done with regular families? I have no trouble filtering out sheets in a similar way. Any and all help is greatly appreciated!
Hi @Colton_Haney maybe try string.contains,
Cheers
@paris Thanks for the quick response! Using String.Contains rather than List.Contains seems to have worked. I am now getting the two lists I was expecting to get. Do you know the reasoning behind why the String.Contains node works but the List.Contains node does not?
List.Contains checks to see if a list contains an item. You supplied one list so you got one boolean back.
@Nick_Boyts Ok, that makes sense. Thank you for the explanation!
