Hi, I’m little bit lost in my attempt to create Python script to get station of alignment where instantaneous radius is smaller than input.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AutoCADNodes')
clr.AddReference('Civil3DNodes')
clr.AddReference('Autodesk.Civil3DToolkit') # import the assembly
import Autodesk.AutoCAD.DynamoNodes as DA # assign alias for AutoCAD nodes
import Autodesk.Civil.DynamoNodes as DC # assign alias for Civil 3D nodes
algn = IN[0]
station = IN[1]
def inR(al, st):
r = DC.AlignmentExtensions.GetInstantaneousRadiusAtStation(al, st)["Radius"]
return r
n = 1
R = 150
s = 900
num = 10
while num > 1:
r = inR(algn,s)
num = r-R
....s += 1
....if s == 100:
break
OUT = s
