Design Speed of Alignments
Is there a way to know the design speed of alignment at discrete stations using python scripts in dynamo
Here is one way.
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
dyn_align = IN[0]
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
output = []
with adoc.LockDocument():
	with adoc.Database as db:
			align = dyn_align.InternalDBObject
			dSpeedCol = align.DesignSpeeds
			for i in dSpeedCol:
				output.append({"Station": i.Station, "DesignSpeed": i.Value})
			t.Commit()
OUT = output
