Error in python code for Station and DesignSpeed
To generate Station and DesignSpeed
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
dyn_align = IN[0]
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
output = []
with adoc.LockDocument():
	with adoc.Database as db:
			align = dyn_align.InternalDBObject
			dSpeedCol = align.DesignSpeeds
			for i in dSpeedCol:
				output.append({"Station": i.Station, "DesignSpeed": i.Value})
			t.Commit()
OUT = output
Hi @Christhian
Try this:
or by using list comprehension in one line:
great @Kulkul
one last consultation to learn more about python in civil 3d using dynamo, any course or book that you can recommend
I haven’t seen any course but I would recommend you start withit and let us know if you hit the wall. Here are few links that might help you:
Great @Kulkul
Hello, the explanation has been very good but I do not understand why it does not work when I do it for a single alignment . I appreciate your answer because I am learning.
This I am testing but has a error:
Could you expand exception.
Yes, this is
@carpeso1 It works for me:
Yes, thank’s for your help. But i do not understand, why the code that i am using is not useful. Thank you so much. :+1: :+1: :+1:
