Using DistanceToAlignment method in for loop
I’d like to query the distances of an alignment from my centerline at every round station using DistanceToAlignment method.
If I use it for an exact station, it works, but when I try to use it in a loop it crashes.
Do you have any idea, what I did wrong?
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
centerline_dyn = IN[0]   # Centerline alignment (Dynamo object)
exg_pav_edge_lt_dyn = IN[1]   # Existing pavement edge - left side (Dynamo object)
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            import math
            # Unwrapping the dynamo objects to access Civil 3D objects.
            centerline = t.GetObject(centerline_dyn.InternalObjectId, OpenMode.ForRead)
            exg_pav_edge_lt = t.GetObject(exg_pav_edge_lt_dyn.InternalObjectId, OpenMode.ForRead)
            # Original start and end stations of centerline.
            start_station = centerline.StartingStation
            end_station = centerline.EndingStation
            # Rounded versions of start_station and end_station.
            start_station_rnd = math.ceil(start_station)
            end_station_rnd = math.floor(end_station)
            # All round station of centerline.
            station = range(start_station_rnd, end_station_rnd + 1)
            # Existing lane width on left side at an exact station. - THIS WORKS
            #exg_lane_width_lt = centerline.DistanceToAlignment(station[50], exg_pav_edge_lt, 0, 0)
            # Existing lane width on left side at each station. - THIS DOES NOT WORK
            exg_lane_width_lt = []
            for i in station:
                exg_lane_width_lt.append(centerline.DistanceToAlignment(i, exg_pav_edge_lt, 0, 0)
            t.Commit()
            pass
OUT = exg_lane_width_lt
DistanceToAlignment_issue.dwg (927.3 KB)
DistanceToAlignment_issue.dyn (8.5 KB)
There’s a parentheses missing at the end of this line:
You can also use try/except if you want to make sure it doesn’t crash if it can’t get the distance to the alignment for any possible reason.
Thanks a lot!
I can’t believe it, it’s not the first occasion :slightly_frowning_face:
An additional question:
Do you get the same warning text as me when you run the wrong script?
Warning: CPythonEvaluator.EvaluatePythonScript operation failed.
SyntaxError : ('invalid syntax', ('<string>', 61, 13, '            t.Commit()\n'))
Yeah, I get the exact same text message.
