Offset Alignment start and End station
I am trying to update the existing offset alignment python code for start and end station but with limited knowledge of coding and API its difficult to get this going. it would be really great if i can get some help in updating code for this function. Appreciate all the support
Things i find so far
Autodesk Civil 3D Help | LockToStartStation Property | Autodesk
Thanks @Assem.Daaboul for the code.
Have updated the code to Create offset alignment and add a widening to it between the start and end station. An attempt to understand the code and combine it from the one of the post to add widening code. Suggestions and guidance are welcome for improvement.
"# Load the Python Standard and DesignScript Libraries
import sys
Add Assemblies for AutoCAD and Civil3D
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
clr.AddReference(‘Civil3DNodes’)
Import references from AutoCAD
Import references from Civil3D
from Autodesk.Civil import *
Import references for Dynamo for Civil 3D
from Autodesk.Civil.DynamoNodes import Alignment as DynAlignment
The inputs to this node will be stored as a list in the IN variables.
dataEnteringNode = IN
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
align = IN[0]
alignmentstyle = IN[1]
offset = IN[2]
startstation = IN[3]
endstation = IN[4]
result =
def cmoalignments(align,alignmentstyle,offset):
global adoc
global editor
global civdoc
try:
    with adoc.LockDocument():
        with adoc.Database as db:
                alignmentId = align.InternalObjectId
                al = t.GetObject(alignmentId, OpenMode.ForRead)
                alname = al.Name
                bbsz = "TEST1"
                jbsz = "JBSZ"
                lso = offset * -1
                # for ease of code reading
                # Left offset Alignment
                leftoffsetalname = alname + "-" + bbsz
                leftoffsetId = Alignment.CreateOffsetAlignment(db,leftoffsetalname,alname,lso,alignmentstyle,startstation,endstation)
                alignid = t.GetObject(leftoffsetId, OpenMode.ForWrite, True);
                oInfo = alignid.OffsetAlignmentInfo;
                oInfo.AddWidening(110, 165, 4.6);
                r = oInfo.Regions[1];
                rent = r.EntryTransition;
                rent.TransitionType = TransitionType.Linear;
                entrydesc = r.EntryTransition.TransitionDescription;
                entrydesc.Length = 25;
                rext = r.ExitTransition;
                #rext.TransitionType(2);
                exitdesc = r.ExitTransition.TransitionDescription;
                exitdesc.Length = 45;
                result.append(leftoffsetalname)
                t.Commit()
except Exception() as ex:
    result.append(ex.message)
return result
Assign your output to the OUT variable.
OUT = cmoalignments(align,alignmentstyle,offset)"
@Assem.Daaboul this code is working fine in Civil 3D 2020, but getting bellow error when run in 2022 version. any way to resolve this error for 2022 ?
tried switching between Python 2 and Python 3 but it didnt helped much.
@shahid.shaikh_C3D, you are right. there are some differences between CPython3 and IronPython 2.7. I’ve managed to run the script in Civil 3D 2022 by updating the try-except. Check the attached graph and make sure to use CPython3.
al_.dyn (93.1 KB)
I am really sorry to disturb you @Assem.Daaboul for this but if i change the start and end of the alignment the code is giving bellow error.
can we add any line in the code to get it working even if its same alignment and only other parameters are changed. for ex. Start station, End station or Offset distance etc.
Change name alignment
Before any test
As @hosneyalaa mentioned you can change the offset alignment names before running the script, assuming you want to keep those offset alignments and create new ones.
In case you just want to recreate the offset alignment on each run, you can delete the previous offset alignments and create new ones. Below is the additional code to do this.
                    # check if alignments exist and delete
                    ofstAlIds = al.GetChildOffsetAlignmentIds()
                    for ofstAlID in ofstAlIds:
                        ofstAl = t.GetObject(ofstAlID, OpenMode.ForWrite)
                        if ofstAl.Name.lower() == leftoffsetalname.lower() or ofstAl.Name.lower() == rightoffsetalname.lower():
                            ofstAl.Erase()
I’m attaching the graph as well.
al_.dyn (93.6 KB)
