Get left/right top corner point of geometry
Hi all,
I am trying to get all the vertex points of geometries but from that list only I want left top corner point or right top corner point or bottom left/right corner point. [any one of them].
Please let me know how to get it ?
@shashank.baganeACM , hi
you can just indexing your desiered point
I have already tried this but for some columns it is not working.
Try with this
Column numbering with columns elimintaed.rvt (3.2 MB)
work around by min/maxPoint?
KR
Andreas
Also tried this but when it comes to rotated columns it wont give correct point. I have checked it many times and for that reason I used vertex nodes.
Check with the file that I have shared
What about something like this:
  • Get the solid of the column.
  • Get the vertices of that solid.
  • Sort & Group them by the X-coordinate.
  • Sort them by the Y-coordinate.
  • Extract the min./max. Point of that list according to the corner you want
@Daan , hi
what do i next ?
Hi @Draxl_Andreas & @shashank.baganeACM ,
Something like this:
jxUaf4NvxQ
2022-05-29 Get Points by the selected corner.dyn (69.8 KB)
Hello M. @Daan
I tried another way (not to compete, to progress)
if I tilt the column (around its z axis) the u,v do not follow the face?
Thanks for the explanations in advance.
Cordially
christian.stan
@christian.stan ,
that looks like boudingbox does not fit!
Yes @christian.stan I agree with you. In some of the tilted columns it wont satisfy the criteria. I have some columns with tilted and checked the same for such conditions. So @Daan how to tackle with this ?
@shashank.baganeACM , check out this:
if the diagram made here is correct (someone more experienced than me needs to confirm)
I leave you the script to move in this direction
forum anglais daan.dyn (25.2 KB)
I had also thought of another way (to make a bouding box including all the columns and to filter by the shortest distances leading to the corners of the columns)
create a function then apply it 4 times and classify them in the desired order with 4 lists at the end.
Capture d’écran 2022-05-31 115023
Cordially
christian.stan
Here is with a bounding box and distances as mentioned
(it can be improved)
forum anglais vers bb.dyn (72.4 KB)
Cordially
christian.stan
