Hi All,
Is there away to get corner points accessed through dynamo as per below?
All i want is to get that blue point you get when you hover dimension tool over element in revit.
Is this even posable?
Regards
Hi All,
Regards
Yes it is possible. That point is actually the vertical line in most cases, but you can use points as well. Look into Genius Loci or the Reference section of the Revit API.
Hello, The Genius loci package has nodes, but read the author’s advice carefully. see screen
Maybe you can look at its code to get it in your direction.
Sincerely
christian.stan
Thanks @jacob.small
Is this only works with familys?
Say i have direct shapes generated by dynamo and im only able to dim to surfaces at the moment.
As shapes are not uniform and i struggling to get 2 refs for dims.
Genius Loci node give me all nulls or empty lists.
Regards
No, it will work with a project as well. I am not sure how to best attain them from your direct shapes though, as I have no idea how they look. Post some files and I might be able to jump into it tomorrow, if someone else does t beat me to it.
Hi @jacob.small Thanks for your time
Please see attached.
DirectShapes dims.dyn (87.0 KB)
DirectShapes.rvt (6.1 MB)
Regards
Hi @dkeinys not sure if something here could work for you
Hi Sovitek,
Thanks for your time.
I don’t have issue creating dims to faces. Issue i have i dont have enough of them to dim to hence why i asked if there a way to dim to points instead.
Regards
havent tried with dim ref point. but probably something goin on when its directshape, i have just very fast tried your example
Hi I tried to dig a little,
I started from one side to recover the curves and edges
But the GetEndPointReference method of the Edge class, I can’t use it, I’ll leave the script to you if you want to dig in that direction
import sys
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI.Selection import *
doc=DocumentManager.Instance.CurrentDBDocument
flag = IN[0]
if flag:
ref = uidoc.Selection.PickObject(ObjectType.Face,"Select a face")
elt=doc.GetElement(ref)
face=elt.GetGeometryObjectFromReference(ref)
lstcurv=face.GetEdgesAsCurveLoops()
lstedges=face.EdgeLoops
refp=ReferenceArray()
refpts=[]
for e in lstedges[0]:
refp.Append(e.GetEndPointReference(0))
refpts.append(refp)
OUT = face,lstcurv,lstedges,refpts,lstedges[0]
cordially
christian.stan
