Hi all,
Trying to do something I thought should be simple but coming across some issues with the relevant nodes and wanted to check I was using them right (or if there is another way of doing what I said the goal was in the title).
I’m using the following Orchid nodes to try and get the parameter values from a FamilyType loaded into the project but not yet placed.
I am getting the family doc & family type but the node for getting values is erroring. The only thing I can think is that the getvalue node is expecting a .rfa document rather than the revit.project document that its getting. Is it not possible to get these values from within a project?
Conversely to this, does anyone know any other methods of getting parameter values from unplaced familytypes shy of creating a family instance, extracting values then deleting it?
Dynamo version 1.3.4
Orchid Version 204.1.4.7536
Thanks,
Jake
