I am trying to use the ElementsSetParameterByName node in a simple graph but won’t get what I want. If I use revit built-in parameters, it works but if I use shared parameter, it fails (pleaseee attached image).
Got it…it’s duct terminal. Tried to revert the process by writing shared parameters to excel but can’t get it. It only writes the built-in parameters into excel (see partial snapshot of my graph).
I would be grateful if you can show me the right direction.
What are you feedinng in that “List.Create”? Are your shared parameters instance of type parameters? To check the parameters of an element there is a node simply called “Parameters” which will show you what dynamo reads
@Kulkul & @GregX, thanks for replying. To enhance this discussion, I think I need to create a separate discussion for this as the original post was already solved.
