Possible to edit electrical circuit parameters?
I’m trying to use dynamo to edit the “Load Name” electrical circuit parameter. The intent is to put that on a panel schedule. When I run the Element.Parameters it does not show that parameter in the list.
When I run the rhythm elements.getparametervaluebynametypeorinstance (nice name haha) it does not return any values.
Any way to be able to use dynamo to edit these parameters??
Hi @wsayle,
If this is a family type make sure to feed in the Family Type and not the Family Instance (or vice versa).
Hello @wsayle ,
In dynamo it suppose to give to value from get parameter / set parameter value by name. I think, you are facing some other problem.
Can you please share a sample Revit & .dyn file, which will represent this type of issue.
Processing: TestProject.rvt…
Processing: Circuit Load ID.dyn…
It would appear that I can’t upload the files. This forum does not allow me too as I am a new user.
Here is a dropbox. Sorry, noob to the forum.
you need to choose ‘Electrical Circuit’ as Category
Another solution is place ‘Element.ElectricalCircuit’ node after ‘All Element of Category’ OOTB node
That works! Thank you!
