Get ceilings and floors in Z direction and set Parameter
i run a old script, i want to understand.
My task is to upadte my “ceilings-Style” and set a room parameter.
i want get the ceiling and put the value to the room.
i think i do not need this boolmask just grabing the elements
i set already a 3D view with all my ceilings and floors
RoomDataFilledByCeilingsData_V02.dyn (50.9 KB)
there should be defnitly more ceilings!
is there a tolerance ?
am i on the right way ?
Hi Andreas …I would say yes :wink: :wink:
@sovitek
i used a old RayBounce node, i got no error, this is the right one
which version are you in, what did the node give you ?..you node looks like datashapes have you tried probably an update or OOTB or bimorph…just my guess you know everything can go wrong :wink: :wink:
@sovitek
it is Datashapes, i can set there to use linked or native models
does it give the right in that output ?
@sovitek
i have 500 ceilings so 600 rooms, that can be right, because we have outside rooms, and ceiling they are framing other ceilings.
årh yeah…thats can be an issue…try test for for not valid room and clean up there
@sovitek
i can skip the filter part tooo, it happend already in the raybounce node
