Get and Set parameter of wall using python
This works?
#Import the Revit API
#Import DocumentManager and TransactionManager
#Reference the active Document and application
elem = UnwrapElement(IN[0])
#elem_param = elem.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
elem_param = elem.LookupParameter("Base Offset")
if elem_param.Set(5):
	OUT = 'Success'
	OUT = 'Failed to Set Parameter'
From here…Looking to set Parameter value with Python. Am I using the correct command? - #4 by MartinSpence
Hope that helps,
Mark
