Looking to set Parameter value with Python. Am I using the correct command?
Hi @dfgind
Here’s something to work with:
Python:
#Import the Revit API
#Import DocumentManager and TransactionManager
#Reference the active Document and application
elem = UnwrapElement(IN[0])
elem_param = elem.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
if elem_param.Set('Hello World'):
	OUT = 'Success'
	OUT = 'Failed to Set Parameter'
Link to the Set() method from the API.
