Hi everyone,
I wish to change some parameters of elements in a linked file and I can´t get it to work. The normal “Element.SetParameterByName” gives the same error as shown in the picture.
#Copyright(c) 2015, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import geometry conversion extension methods
#doc = DocumentManager.Instance.CurrentDBDocument
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
doc = UnwrapElement(IN[1])
data = IN[0]
for d in data:
d.SetParameterByName("Raumbegrenzung",False)
OUT = doc
I´m suspecting that the Revit Node “SetParameterByName” does not use a doc. Do I have to use the Revit API to set the parameter or is there a mistake in my code?
Thanks and kind regards,
Jannis
