Get and Set parameter of wall using python
Hi I am trying to get parameter and set parameter of base offset of wall. So I manage to the value of base offset of wall but facing difficulty in setting the parameter value.
The code goes as below. Please let me know how do I set values to base offset ?
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
ele = UnwrapElement(IN[0])
params = ele.LookupParameter("Base Offset")
bsofst = params.AsDouble()*304.8
OUT = bsofst
This works?
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
elem = UnwrapElement(IN[0])
#elem_param = elem.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
elem_param = elem.LookupParameter("Base Offset")
if elem_param.Set(5):
	OUT = 'Success'
	OUT = 'Failed to Set Parameter'
From here…Looking to set Parameter value with Python. Am I using the correct command? - #4 by MartinSpence
Hope that helps,
Mark
Thanks @Mark.Ackerley I appreciate that. It works
