Set Parameter by Name, how?
i just want to set my collected values to a parameter… BUT i lost my way :wink:
clr.AddReference('RevitAPI')
clr.AddReference('System')
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms)
rooms = collector.WhereElementIsNotElementType().ToElements()
t = Transaction(doc, "Set SpaceNumber")
def SetParameterByName(Element,ParameterName,Value):
	rooms.LookupParameter(ParameterName).Set(Value)
t.Start()
param_c=[]
for i in rooms:
	p = str(i.LookupParameter("Bauteil").AsString())
	q = str(i.LookupParameter("Geschoss").AsString())
	r = str(i.LookupParameter("Top").AsString())
	a = "M03" + p + q + r
	#param_c.append(a)
for r in UnwrapElement(rooms):
	param_c.append(r.SetParameterByName(r,"SpaceNumber",a))
t.Commit()
OUT = param_c
in Dynamo it is a easy task, but how do i this here…
KR
Andreas
If you’re going to use the Dynamo method you have to provide Dynamo objects. You’re currently providing Revit objects. The alternative is to use the Revit API to set the parameter values.
@Nick_Boyts ,
at least i got no warning
BUT it remains empty, final aim is to set the compined strings
KR
Andreas
Why are you using two for loops?
Try this:
# Retrieve all rooms in the document
rooms_collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType()
rooms = list(rooms_collector)
# Start a transaction to modify the parameter
transaction = Transaction(doc, "Set SpaceNumber Parameter")
transaction.Start()
for room in rooms:
    # Check if the parameter exists in the room
    space_number_param = room.LookupParameter("SpaceNumber")
    if space_number_param:
        # Retrieve the values of other parameters
        bauteil_param = room.LookupParameter("Bauteil").AsString()
        geschoss_param = room.LookupParameter("Geschoss").AsString()
        top_param = room.LookupParameter("Top").AsString()
        # Construct the value for SpaceNumber parameter
        space_number_value = "M03" + bauteil_param + geschoss_param + top_param
        # Set the new value for the SpaceNumber parameter
        space_number_param.Set(space_number_value)
# Commit the transaction
transaction.Commit()
@gerhard.p ,
i understand i use the variable first get the parameter
and the same variable to set the parameter
via my collection
ok it works … for any reason i have to use str(
This is 100% ChatGPT code^^
I use it for everything I’m coding and making much more progress since I do because:
  • I can ask for every single step why it is coded like that and i get detailed explainations
  • I can ask to code some parts in a different way
  • I can ask to add or remove things.
  • the naming of variables is better as if I did it myself
And so on.
Give it a try
