Hi everyone,
I’m making a dynamo and I want to get all the elements of a picked family.
Can you explain me how I can do this ?
Thx
I showed you, the lower part of the image:
FamilyInstance.GetFamily > Family.Types > All Elements of Family Type
Is it not what you need?
@m.quijada as @lucamanzoni mentioned, that’s what you need.
ok it works now
Thank you @3Pinter & @lucamanzoni !!
you are welcome!
ps. mark a reply as solved to help others.
done
@3Pinter ok, but this is to get all the elements of a type, not of a family (and it’s the same as the top part of the first graph I posted).
Let’s say you have a IPE beam family, with 3 types (180, 240, 300), each one 3 elements (9 in total).
In this way you get only the instances of the same type (i.e. 3 x 180), not all the IPE beams.
I was working on something like this, maybe it can be simplified further:
PS. From which package is StructuralFraming.Type node?
I spent at least 15 minutes looking for it and couldn’t find it, I probably need a holiday. I will look for it again tomorrow
Grab that good-morning-coffee and you’ll find it at Revit > Element > StructuralFraming > Type
Thanks @3Pinter , I found it but only in version 1.3, same for node FamilyInstance.GetType.
When I open Dynamo 2.0.2 (the one I always use), I don’t have those nodes.
Here from 1.3:
And here from 2.0.2:
So I wasn’t actually completely blind
But actually it’is weird, because in the Dictionary it says version 1.x 2.x
Which version are you using?
True! I guess they replaced the StructuralFraming.GetType and FamilyInstance.GetType to a more generic (and better) ElementType!
The methods are however still available usign a codeblock:
Yeah, better and more logical approach.
Oh well, more reasons to go to 2.x!
Hello Luca,
I have a similar problem, but I’m not sure how to solve it. I want to select a specific family that has a lot of types and those types that are in use to assign them numbers.
I did it but only for one type, but I want to do it for all types that are active.
Thanks in advance
Liebe Grüße
N.Nikolic
