Geometry.Split in Revit API
Hi community!
Does anybody know if there is an equivalent of the Geometry.Split node in the Revit Api?
I’ve got the volume of a room, then I got its solid geometry and from the solid I got a face (Planar Face) and I would like to cut/split it by a plane getting two faces, I’ve managed to do it in python with the Geometry.Split but it uses ‘Autodesk.DesignScript.Geometry.Surface’ not ‘Autodesk.Revit.DB Face’.
I’m aware of the CutWithHalfSpace method, but it requires a solid not a face.
Any idea about how to achieve it?
Thank you so much in advance!
There is the following face method Intersect Method (Curve, IntersectionResultArray) in the API
Thanks for the insight Mike,
But then, if I understood it right the intersect method returns an array of elements and in my scenario where I’m intersecting a face against another face or a plane against a face, the return I will get I assume will be an array of curves as a curve/line is the result of an intersection of two faces.
But actually what I’m expecting to get as a result are the result faces, the same It returns the Geometry.Split node in Dynamo.
Thanks again!
