Geometry Intersect not working
I try to use the geometry.Intersect() to find the intersected geometry between two geometry. It worked before if I input use geometry as input. However, I want to use element as input this time(Like the captured image below). And errors happened in the python script. In what step do I go wrong?
Thanks.
ducts = UnwrapElement(IN[0])
rooms = UnwrapElement(IN[1])
duct = ducts[0].Geometry[Options()]
room = rooms[0].Geometry[Options()]
result = duct.Intersect(room) #Error on this line
OUT = result
Hello
Autodesk.Revit.DB GeometryElement (List) has no Intersect method.
You cannot use objects from one API (Revit API) to another API (Dynamo API) without conversion.
an example with Dynamo API
import sys
import itertools
clr.AddReference('RevitAPI')
elemsA = IN[0]
elemsB = IN[1]
intersect = []
geoSetElemsA = elemsA[0].Geometry()
geoSetElemsB = elemsB[0].Geometry()
for geoa, geob in itertools.product(geoSetElemsA, geoSetElemsB):
	if geoa.DoesIntersect(geob):
		intersect.extend(geoa.Intersect(geob))
OUT = intersect
here is a useful link
thanks for your reply. Does my understanding in the grouping as below is correct?
room = rooms[0].Geometry[Options()] #Revit API
result = duct.Intersect(room) #Dynamo API
Moreover, how can I know which object is from Revit API or Dynamo API?
Is that everything from this doc is belonged to Revit API?
https://www.revitapidocs.com/2015/d8a55a5b-2a69-d5ab-3e1f-6cf1ee43c8ec.htm
About the conversion you mentioned, is that UnwrapElement covert the object Dynamo to Revit and I need to covert back in order to use the Intersect() ?
Thanks.
No, if you want to use Intersect method (Dynamo) duct and room must be Dynamo object (Dynamo Geometry object)
You can use GetType() method
Here some link about the wrapper and geometry conversion;
