Hi All,
I’m a new here and a beginner in dynamo. I am creating a 2d geometry in dynamo (column schedules specifically) and then run it into revit. Did someone here encounter this problem already? Circle lines that I have created were not really closed when it comes to revit and seems to be fine in dynamo. Are there any solution for these?
Also I want to fill this circle with solid patterns but I don’t know how to put it into revit. I actually hatch it in dynamo using “Surface.ByPatch” but I want it also to generate in revit.
I would appreciate if someone replies on this issue. Thanks!!
