Geometry Scaling and Dynamo Player in Revit 2024
Hello everyone,
  1. I’ve set my Geometry Scaling to Extra Large in Dynamo 2.18 in Revit 2024.1, but I’m still getting this warning.
  2. Even if it’s suppressed/fixed, does this mean that everyone using this graph needs to manually change their Dynamo Geometry Scaling setting? Is there a way to embed this setting into the graph itself?
  3. Additionally, I can’t seem to find the ‘Edit inputs’ option in Dynamo Player in Revit 2024. Is this the expected behavior, where you directly run a graph and receive warnings for missing inputs (if any)?
Don’t. Leave it at medium and ignore the warnings. Otherwise you are discarding accuracy and things will discard their data on geometry manipulation.
One fix if you want to avoid the scaling warning: work in meters or feet, and keep your model within the limit of Revit’s geometry limit.
Just for info, these are my outputs
