Geometry.Intersect Revit 2024
I encountered an issue with the Geometry.Intersect Node when attempting to upgrade a script from Revit 2021 to Revit 2024, as shown in the image. Can you please offer some guidance on how to proceed?
Was this run on the same model? Have you confirmed it still works in 2022 and 2023 (both of which have quite a bit of changes in terms of how rebar works)?
Yes, I ran the script in the same model. However, I have not tested this script in Revit 2022 or 23.
Because of the many changes in rebar tools between the two builds you may run into a situation where the previous method will not perform the same way. Test the in between versions to see if the change happens in a particular year.
Also be sure that your geometry scaling is the same in all cases, as that can cause similar problems.
It’s important to note that the Geometry.Intersect node hasn’t changed, so the discrepancy is likely in the geometry collection method - hard to know without seeing more though.
