Geometry.DoesIntersect shows all false
Why is it that the Geometry.DoesIntersect node shows all False when the elements are actually intersecting and generating an intersection point?
Thank you
J
Hi @Joaquim_Agostinho1
Which Dynamo and Revit version your using?
1.3.3 and Revit 2018.3.1
@Joaquim_Agostinho1 Could you please drop rvt here?
Grids Renaming.rvt (2.2 MB)
@Joaquim_Agostinho1 After testing your rvt file i also got the same result as yours, It might be due to your nurbscurve issue. However after adding Curve.approximatewithArcandLineSegments node it works fine.
Thank you. That’s it.
