Geometry.intersect node not showing the intersection
im trying to get the intersection between pipes & framings they do intersect but node shows nothing
Can’t say exactly without testing, but experiment with the lacing and @Levels for the intersect node. Geometry @L1, Other @L2, lacing longest maybe?
Set the Lacing on the Geometry.Intersect node to cross product lacing it will work.
not working either. any other idea?
please share the files here so that the error can be checked.
Sleeve dynamoV1.dyn (18.2 KB)
above this i’ve shared the dynamo file & the rvt file i cant share more then 8mb files so u can download from my workmate’s drive
it is working
not in me what version u useing im on revit 2022
set the lacing to cross product in geometry.intersect node
yes that worked thanks a lot.
